I'd like to convert a .mpg to .wmv Googling hasn't helped (I found the Windows Media Encoder, but it apparently won't handle MPEG2 files), and searching here brought up a bunch of irrelevant links![]()
you can try windows movie maker or tmpgenc xpress or https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=to+WMV&dvda...+or+List+tools
or make an avisynth script and convert with WMNicEnc -
What is the easiest way to do this?
I import the .mpg into WMM and drag it to the storyline. I then choose File, Save Movie File. For Movie Location, I tell it "My Computer". It asks for a file name and location. It then estimates that, at "Best quality", I'll need 1.56MB to get a 160X120 38Kb/s file, which seems completely wrong... the source file is 200MB from a ReplayTV. If I choose Next anyway, it tells me:
"Windows Movie maker cannot save the movie to the specified location. Verify that the original source files used in your movie are still available, that the saving location is still availble, and that there is enough free disk space available, and then try again."
Of course, there is more than enough disk space, the source file is still there, and I've tried a few different saving locations on different disks, all of which otherwise work just fine. The Help doesn't address any of this at all. -
I seem to recall WMM having issues with MPEG-2.
Personally I'd convert it to DV-AVI using VirtualDub and the Panasonic DV codec, and then open that in WMM.If in doubt, Google it.
WMV to MPEG2 converter
By siluet in forum Video ConversionReplies: 1Last Post: 5th Oct 2008, 12:13 -
How do I include wmv to a dvd with mpeg2?
By Jensen in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2008, 20:50 -
Anyone knows how to convert ASF / WMV to Mpeg2
By macuser1960 in forum ffmpegX general discussionReplies: 3Last Post: 9th Feb 2008, 16:38 -
Quick Conversion of Mpeg2 to Zune-compatible WMV using AutoMKV
By dlflannery in forum User guidesReplies: 4Last Post: 31st Dec 2007, 20:45 -
Best App for Converting MPEG2 files to WMV/WMA 5.1
By JBredensteiner in forum Video ConversionReplies: 13Last Post: 7th Oct 2007, 14:58
