hi, i have pinnacle studio 7, and edited a home video with it. i soon realized i needed a bigger harddrive to keep working on it, so i saved the almost complete home video into an mpg because there wasnt enough room on the hard drive to make it into an avi. now that i have a bigger hard drive, i wish to re-edit it back in pinnacle, but i cant convert the file (well over 1 gig) into an avi file, which is the only kind of file pinnacle will recognize to edit. ive tried all the major recommended progs like virtualdubmod... im sure i would need to convert it into a regular avi file (likely around 12gigs) and not a divx file, so that pinnacle can recognize it...
my only other option, which is getting the mpg back on my mini-dv camcorder, is also not working. i converted the mpg into a dvd and then tried capturing the dvd through my dvd player into my mini dv camcorder, but the camcorder said "copy protected" and wouldnt record. i used TMPGEnc DVD author to make the dvd and i couldnt find any option to get rid of copy protection. if anyone knows how i can accomplish this, it would be much better than having to download another program, as ive downloaded half a dozen "mpg to avi" type progs that dont work.
any suggestions in either direction will be most appreciated!
why doesn't it work with virtualdubmod? any error msg when you open or convert?
try also virtualdub-mpeg2 and convert to huffyuv or panasonic dv
you can also try frameserve to pinnacle studio...i haven't tested it though, www.videohelp.com/virtualdubframeserve -
i cant remember what the error was with virtualdubmod, and ive deleted the prog already... i think the avi file would have been too big using it. i remember that the avi file that would have been created with pinnacle wasnt that big, but with virtualdubmod, it was like hundreds of megabytes in a few seconds! maybe i didnt use the right settings...
Help burning Pinnacle project to DVD...mpg, converting, etc.
By jubbilee in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2011, 14:37 -
Pinnacle AV/DV Card - problem with color
By leniwiec in forum Capturing and VCRReplies: 1Last Post: 2nd Jun 2010, 17:48 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
pinnacle 11 - sound capture problem
By lhg033 in forum Capturing and VCRReplies: 3Last Post: 1st May 2008, 19:56 -
Pinnacle DVD Problem?????
By Kmbfd558 in forum Authoring (DVD)Replies: 0Last Post: 15th Jul 2007, 08:31
