i try to demux a VOB file with virtualdub but all I get is a AVI file that has no sound....
(i am pretty noob, an searches on the forum have not helped me...)
Hi,
What are you trying to make? If you're trying to make a avi to watch on your pc you need a mp3 compressor like lamemp3 or something else. then you go to audio-full processing mode - compression and select your compressor.
you don't demux vob with virtualdub. use something like vobrator or tmpgenc.
... or VOBEdit. There's instructions on how to demux in VOBEdit within this guide (Step 1).Originally Posted by BaldrickIf in doubt, Google it.
Hi!
Ok, lets put it this way:
I actually try to convert a VOB file into an AVI file, which I can import into Premiere for further editing.
VirtualDub - Editing and Fixing Sound
By bpatters69 in forum EditingReplies: 1Last Post: 26th Oct 2009, 13:33 -
problems adding 5.1 sound using virtualdub mod??
By pete7769 in forum AudioReplies: 4Last Post: 24th Jul 2009, 16:45 -
Virtualdub and sound problem
By Shabaman in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 09:55 -
Virtualdub used with or without AviCutter=Sound Synch Problem
By johnharlin in forum EditingReplies: 11Last Post: 29th Dec 2007, 12:13 -
VirtualDub can't decompress the sound.
By KOJV in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2007, 19:59
