  1. Real basic question, if anyone can help me out with this it would be great: how do I download TMPGEnc without having a zip drive, and what exactly is a zip drive?.... Is there a way to download TMPGEnc without it?.... Thanks!
    Feb 2001
    Kalmar, Sweden
    Not sure what you mean...
    ( Right click links and select "Save As" )
    Direct link: http://www.tmpgenc.com/files/TMPGEnc-2.02.31.119.zip
    Link to VFAPI: http://www.tmpgenc.com/files/TMPGEnc-2.01.30.116-vfp.zip
    Just download them to your HD and unzip...
    A zip-drive is like a diskett-drive with disketts that have the capacity of 100MBs or more...
    _________________
    Magnus Jensen
    A.K.A Geezus
    <font size=-1>[ This Message was edited by: KuskenLars on 2001-12-19 00:43:13 ]</font>
  3. Thanks for replying!... I right clicked and saved to my hardrive, but when I go to open the TMPGEnc-2 file I get a microsoft pop-up window that says: "windows cannot find mplayer.exe... this program is needed to open files of type ZIP file"..... any idea what I should do next?...
  4. Zip is a compression format. Basically you take a whole bunge of files (and dirs) and compress them into one file. This makes it easier to send/recieve it over the net.
    Dload winzip (http://www.winzip.com or http://www.download.com) install winzip and you'll be able to uncompress the zip archive.
    Aside - another popular compression program/type is rar.
    Dec 2001
    NSW,Australia
    Use Winace as it will open .ace .rar and .zip extensions no need for multiple programes.this does them all
