  1. whats best program to convert avi to vob which dont drain memory and is quite fast
  2. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    Define "best" ...
    Certainly one of the easiest one step solutions is VSO DivXtoDVD (pre v. 0.6 is free). Otherwise do a SEARCH or look in the Convert Section to the left
    - e404pnf
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by e404pnf
    Define "best" ...
    exactly.
    There is no best.
    There is what's best for me, what's best for you, what's best for Baldrick .... and you get the idea.
    How's about going to the tools section, and clicking on the "All in one DVD converters" subheading ?
    ... or going to the guides section, and trying a few out ?
    All the info is right here at your fingertips
    If in doubt, Google it.
    Feb 2004
    I am a free man.
    OOOOO i love these 'what is best' threads.....
    But seriously use the search option, it'll find you tools and guides and threads where people have asked the same question before!!
    There are no tools that do AVI to VOB as such....
    but presumably you really want
    AVI to DVD
    Guides for such a conversion HERE
    they are all going to use quite a bit of memory, and unless you set them to be working in the background or as low priority, I wouldnt recommend doing anything else on the PC at the same time.
    And damn you Jimm....beat me to it!!!!!
