is there a program that use to increase BIT TORRENT speed? for free?? where can i download it? i heard it somewhere, but just forgot the name. i found this one, but we have to buy it, and i can't find the free-trial version of it. although, it did say free trial for 15 days, but when I download it, i can't use it until I buy the software. so please... can anyone help me find that program?? thanks in advance!!
THE BITTORENT ENGINE THAT I FOUND:
Link Removed
Results 1 to 18 of 18
you might try bit tornado. it has an adjustable upload speed.. if you max out your upload speed it will severly decrease your download speed.. i usually leave my torrents uploading about 4 or 5 k below my max upload speed so i will get full download speed..
No. Properly configured router with opened and forwarded ports. And a good and properly configured Bit Torrent program is all you can do.
That software sounds like crap. Go get a real BT client like Azureus or one of the easier to setup ones. -
Bit Comet works for me. You can fine tune it a little, but you won't gain much in the way of speed. I don't like Azureus as it uses Java, which I don't trust, but I admit it's easy to set up, especially with firewalls.
Setting up more connections and more half-open connections help, but your ISP won't like it.
If you really want the best speed, use a good program and study their forums. You will find the best recommendations there. -
well as every1 said a good BT client and router/firewall settings wud do the trick cause say suppose u d/lin from 56k u wud get only 2-3kbps speed even if u wanna tweak ur connection.in the BT network everythin is on seeeders connection
Originally Posted by lumis
Originally Posted by Flaystus
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
yep you can dramatically increase your torrent downloads the same way you can eliminate traffic on the way to work...you'll have to exterminate lots and lots of people, however.
Originally Posted by VCDHunter
However those who "tough it out" often find there is a reason its used by alot of people. -
i've been using BIT TORNADO. the sped for my connection is 1-2 kbs. i don't have a high speed internet and is using dial up connection. that's why my speed is so slow. i guess that we have to have high connections in order to increased the speed. oh darn!!
lilcuteeguh if you are on dialup, then that's the real problem. P2P needs a lot of bandwidth for the most efficiency. A 4GB file would take days and days on a 56K connection.
Maybe someone here has a P2P program suggestion that would work better on dialup? -
ill put in a vote for Azureus but not if on dial up.. ive tried them all or most of them. and even though ive gone back and forth i always end up back with Azureus i love all the plugins and features.. sure it uses java.. but so what.. its a freggen awsome BT client..
I guess my problem with Azureus besides Java is it punches holes through my firewalls and that makes me nervous. Yes, that makes it easy to use, but I value security more than convenience. I would just as soon reduce my exposure to outside influences as much as possible, even at the cost of speed. I disable UPnP and use a proxy server. Azureus seems to go right around this.
Maybe I'm just paranoid or maybe they really are out there trying to get me. -
i have a few questions to ask you guys. what are Azureus and P2P Program? i'm sorry because i'm not that good in these software stuff. thanks!!
P2P= Peer to Peer. The usual method of filesharing over the internet.
There are a lot of filesharing clients. Some such as BitComet use 'torrents' to locate and download the files. Used primarily for large files, such as video. Azureus uses the same method, just the program works differently.
Other popular P2P programs for smaller files are Emule or similar.
Audio, such as MP3s use a program like Napster.
You can see a listing of some P2P clients here:http://directory.google.com/Top/Computers/Software/Internet/Clients/File_Sharing/
As you can see, there are quite a few. We all have our favorites.
Many of these programs are used to download copyrighted or illegal files, which we do not discuss here. This is a strict rule and violations will get you banned.But you can discuss the P2P programs, though this is a video forum and you will get much better details from P2P sites.
Azureus is a good BT client, it connects to torrents that other clients can't. But, it is a horrible resource hog, often taking 100% CPU time and a hell of a lot of RAM. I used all the steps suggested by the FAQ, but never could get it lowered to an acceptable level. I think my machine is decent, at least enough to run Azureus (see specs in Computer Details).
i'm currently downloading a torrent file that is 700 MB. so Azureus can also download torrent file right? and that it can speed up? thanks in advance!!
Have you not read anything posted in this thread ?
It's all about the configuration settings
I've used Azureus and BitComet, and had both running successfully. However I lean towards BitComet, mainly because it is a bit more straight-forward and just easier to do certain things that both clients can do.If in doubt, Google it. -
Originally Posted by redwudz
if you are, just disable the UPNP plugin. Whoever thought that standard up should be shot.
Is there a program to clean mp3 file of torrent traces?
By aqualung2003 in forum AudioReplies: 3Last Post: 1st Jun 2011, 00:29 -
32-bit program Micrografx on 64-bit windows vista?
By Obamargarine in forum ComputerReplies: 8Last Post: 11th Aug 2009, 18:56 -
Ripbot264 possible speed increase?!?
By cjbrown80 in forum Video ConversionReplies: 3Last Post: 10th Feb 2009, 10:26 -
Remain Bit rate or increase when convert to dvd?
By sychern in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 18:26 -
Speed increase?
By calbear94 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Jul 2007, 08:45
