I am currently running:
athlon xp 2500+
512DDR333
geforce ti4200
sound blaster live!
When i try to encode my video after editing in vegas 4.0 (encoded as dvd ntsc mpg) the audio and video are out of sync for the last 2-3 minutes of a 27min clip. Is this becuase of my computer specs or is it because of some other reason?
Hi Buddyboy,
I'd say your computer specs are OK. Maybe you could do with more memory, but I very much doubt that'll be causing your problem.
How does the "out of synch" manifest itself? Is it:
a) OK and then suddenly out?
b) OK and then starts to gradually go out?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
"Encode", not render.
Source of the original video clip will sure help. Is it styraight from a DV cam ( Ideal ) or from some other "Iffy" source?
No DVD can withstand the power of DVDShrink along with AnyDVD! -
at the start the audio/video is fine and it gradually loses the sync
i captured the video with my leadtek winfast 2000 deluxe card, from a vcr, in mpeg-2 format at 4233kb/s bitrate.
the original clip is fine and in sync -
I just tried encoding the last 4 minutes only of the clip and it worked out fine. But the full clip loses the sync
I wonder if there's a bad frame(s) in there that might be triggering the problem? That's a stab in the dark as I don't capture / edit MPEG, nor can I recommend any tools to see if there is a bad frame.
Hopefully someone else can step in and be of more help... Sorry I couldn't help more?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Installed ffdshow and now my computer is really slow
By AaBbCc in forum ComputerReplies: 3Last Post: 3rd Jan 2012, 10:11 -
Is my computer too slow for playing 720p ?
By Hazizo in forum Newbie / General discussionsReplies: 13Last Post: 12th Sep 2011, 21:17 -
Fast encoding on a slow computer
By si4h in forum Newbie / General discussionsReplies: 11Last Post: 5th Aug 2010, 12:09 -
MTS to AVI on slow computer
By Mort126 in forum Video ConversionReplies: 1Last Post: 29th Jun 2010, 16:01 -
help slow computer, Hijack this report
By maxamillion in forum ComputerReplies: 13Last Post: 22nd Apr 2009, 00:38
