Anyone know any good mpeg 4 compressor software that will play back on my motorola. Most new motorola phones are capable of playing mpeg 4 files. However, I've been unable to get my phone to play videos I made on dr. divx. Any advice is appreciated.
Results 1 to 11 of 11
Only a guess, but your Motorola might only handle AVC/h264 MP4 files. Check the documentation, there must be something about this. Also try encoding with Super - http://www.softpedia.com/progScreenshots/SUPER-Screenshot-23696.html
I doubt it would be AVC. My guess, SP MPEG-4.
Dr. DivX outputs DivX/mp3 avi's. Your phone I would imagine supports mp4 files. Now you could remux your avi to mp4 using say mp4box, however I don't know what exactly your phone supports, so it still might not work.
Also I would use XviD and not DivX, also aac audio instead of mp3 if it supports it.
A lot of phones also only support h.263/amr 3gp/mp4's. -
My Motorola V980 plays WMV files encoded with Windows Media Encoder.
I suppose I should give my phone model. Its a motorola V600. It only has 5 mb of memory so I highly doubt it plays .wmv. I know it plays mp4 I checked the specks, and it even has a motorola commercial sample video on the phone. Anyway, I bought this over priced wireless computer connection to my phone. I've gotten all kinds of mp3 files on there for ring tones, but cant get mp4 on. Unfortunately the stupid blue tooth hardware didn't come with any info on downloading mp4. I'll check on what you guys said, and if anyone can think of any other software let me know.
You'll not get much MP4 on your phone either with only 5 meg of memory. Do you not have the option to upgrade the memory ?
I put a 256MB card in my V980 to replace the 32MB card it came with.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
