  1. DVD2SVCD is a remarkable front end program.
    The quality of the video comes out near perfect!
    But the problem for me is, the second CD won't play.
    Anyone know why?
    I'd have to go through the folders using my DVD player and find the DAT file and play it, but then I lose the ability to show subtitles, like I can in CD 1. What's wrong?
    -= The VidKid =-
    www.TheVidKid.com
    If you want my ICQ#, MSN or Yahoo Messenger ID, just ask. :)
  2. what do u mean "won't play"?
    you mean winDVD/powerDVD won't automatically play it once you insert the SVCD into CD-ROM?...make sure you set the defult drive in winDVD/powerDVD options as your CD-ROM drive.
  3. No.
    The first CD can play automatically and has the ability to play the selectable subtitles in multiple languages.. BUT, the second CD won't play automatically. I have to go through all the folders and then play the DAT file itself. And I'm talking about my stand alone DVD player.
    Basically, CD1 works, but not CD2.
    Any idea/suggestions?
    -= The VidKid =-
    www.TheVidKid.com
    Feb 2001
    Palmdale, CA
    sounds like a corrupt disk, need to reburn.
  5. Tried that. No go.
    -= The VidKid =-
    www.TheVidKid.com
  6. i haven't personally dealth with dvd2svcd, since i perfer having control over the separate programs for each task along the way....but i'm guessing it could be a problem with cutting the dvd rip...try cutting it again...
