Hello.
I'm trying to convert my widescreen DVD to fullscreen using Sefty's converting guide.
After I rip the files and frameserve it in DVD2AVI, I put the d2v file in the source and it says: File not supported.
What can I do to fix this?
I tried doing what the post said and It still wont accept the file.
Any other ideas? -
I made the priority to 2 and it still doesn't work.
I haven't tried re-creating the .d2v file but I will try that now.
I'm using DVD2AVI Version 1.77.4
Should I use 1.76 instead? -
Ok..I used DGMPGDec instead of DVD2AVI to recreate the .d2v file and it worked perfectly.
Now, I wanna change the aspect ratio of the movie from Widescreen to Fullscreen.
How would I do this in TMPGENC?
NOTE: Please no flaming or explaination about how I will lose 1/3 of the video when converting widescreen to fullscreen. I know this already and dont need to read it again.
Thanks. -
Well..could you tell me how to do both just in cause I come pass either one?
New to HC Encoder: .D2V files as input?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2011, 09:41 -
Accepting a Live Video Stream as input
By jay.kert in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Oct 2011, 13:31 -
toast not accepting some movies converted to pal as is
By jboyd in forum ffmpegX general discussionReplies: 4Last Post: 24th Jan 2008, 19:10 -
any demuxers other than dgindex create d2v files for avisynth?
By ecc in forum Video ConversionReplies: 3Last Post: 4th Dec 2007, 10:43 -
splitting *.d2v into separate files for xvid conversion
By greenbag in forum Video ConversionReplies: 15Last Post: 22nd Sep 2007, 17:14
