Ive captured some video in MPEG-1 352x240 (VCD res) from a home VHS, and would like to author it onto DVD. Now I know the basic dvd structure, I know it uses MPEG-2 as well (i think 720x480), and about the AUDIO_TS and VIDEO_TS folders.
I figured the easiest way to do it would be with nero's dvd video tools, or maybe nerovision express which i still need to play with. but assuming im using nero, it wont let me add my MPG file because obviously its not IFO/VOB format. I thought it would take the mpeg and make it the correct format but apparently not (figured mpeg was better than avi with some silly codec).
If i capture it as MPEG 2 say 480x480 or 720x480 will that make it easier, or is my file fine and im just missing some clue? Please let me know, thanks.
MPEG-1 352x240 should work fine, try something else than nerovision crap express like tmpgenc dvd author.
Thanks for the tip baldric i will do that. Im a fan of tsunami products so ill definitely give it a try. i looked it up on their website and it looks like exactly what i need, thanks.
ps lmao @ baldric.. i remember black adder.
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 05:31 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
MP4 conversion to mpeg for DVD authoring
By npereira in forum Video ConversionReplies: 8Last Post: 2nd Jun 2009, 05:20 -
Please offer suggestions for 352x240 mpg...dvd is pixelated...
By AshleyQuick in forum Video ConversionReplies: 3Last Post: 29th Apr 2008, 01:13 -
DVD Authoring Using MPEG-2 Files
By kvanderstarren in forum Authoring (DVD)Replies: 2Last Post: 12th Oct 2007, 15:40
