Hello All,
I recently added a TBC-1000 to my JVC9911 capture setup.
I think I am ready to add a color corrector, but am lost in this department.
I am mainly capturing billiard matches to convert to DVD.
On many older tapes, the colors of the balls are very hard to distinguish as they are small in relation to the entire screen size. Sometimes the purple, black, maroon, and blue balls all look similar shades.
Would a color corrector help me in this situation???
Some tapes, there is also a lot of red or blue push. If the lighting at the billiard tournament was not that good to begin with, am I going to have any success with the corrector?
Suggestions for a unit? I see a lot of people talking about a Sima CC 2 and a BVP-4. What do you think would be most effective for my captures?
You might look towards the end of this thread. There are some examples of what a color corrector can do.
https://www.videohelp.com/forum/viewtopic.php?t=239205 -
Dkolacz
When video is recorded on VHS tape, it records the luminance and delays the chroma 1 line (2 scan lines because of interlace) as chroma takes more processing. So after a few generations it is possible for lipstick to creep down to the chin and people with black hair (no color) will have white foreheads close to the hairline. The smaller the object, the more noticable the shift.
To shift the color back to where it belongs, use a VirtualDub filter called TV and select Chrominance shift up. If it's a second generation tape then add the filter twice.
It may not solve all your chroma problems but should be an improvement.
Regards,
Chas -
Unless you use very expensive equipment, analog color correction is limited to global full image adjustments.
The main goal preparing analog for the A/D is to steer luminance and UV to correct levels so that the full signal is digitized. Once in digital form, sophisticated primary-secondary color correction techniques can be used including masking corrections to small portions of the image.
http://www.kenstone.net/fcp_homepage/cc_legal_fcp4.html
http://www.wideopenwest.com/%7ewvg/tutorial-11.htm
http://www.synthetic-ap.com/Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
@ Dkolacz
Was this issue done using a DNR setting of your vcr ??
I was asking, because the filtering may be adding to the
phenomina you exampled. So, my next question would be,
did you try w/out any filtering turned on in your vcr ?
..and then compared both versions ?
curious.. what is "billiard matches" anyways ??
-vhelp 3482 -
Think Snooker with less balls (if he talking about true billiards)curious.. what is "billiard matches" anyways ??
http://www3.sympatico.ca/eric.perreault/defaulthtml.htmlRead my blog here.
9-ball is fun, so is one pocket. Takes a lot more skill than regular pool.
Back on topic...
As far as color correction, I agree with what edDV said. Proc amps are great but pretty much anything under $1000 cannot do individual colors, it does ranges of luma and chroma adjustments.
For individual colors ... TMPGEnc, Vegas, Premiere, VirtualDub ... those are your friends, all software.Want my help? Ask here! (not via PM!)
Time Base correctors
By Spektre in forum Capturing and VCRReplies: 8Last Post: 22nd Aug 2011, 22:50 -
cheap color TV question
By jimdagys in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2010, 20:07 -
Time Base Correctors
By josel in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2010, 12:01 -
Color space question
By mourya in forum ProgrammingReplies: 2Last Post: 22nd Dec 2008, 19:08 -
Avisynth-Tweak color-question
By SerbianBoss in forum EditingReplies: 4Last Post: 9th Sep 2007, 09:30
