Closed Thread
Results 1 to 13 of 13
    Jun 2005
    Oakland
    Ok, I know how to convert the raw video data to NTSC, but now i have a problem.. I downloaded a DVD Video_TS Folder, with the menu files and everything.. Well, i would like to convert this to NTSC, but still retain the menu.. When i load the folder into say, Tmpgenc DVD Author, it only loads the titles and chapters, but doesn't retain the menu.. I need the menu, is there a way the I can convert this to NTSC and also have the same menu that came with the original PAL/VOB files?
    Jun 2005
    Oakland
    Wait, is this a guide or just software recommendations? i need a step by step guide... also like i said, i'd like to keep the menu intact, that link is confusing, i'm not sure if it's helpful..
    Aug 2001
    Montrel, Quebec
    Originally Posted by Baldrick
    DVD PAL to NTSC or NTSC to PAL DVD converter toools:
    diko, can not keep extra material
    or
    avi2dvd, can not keep extra material
    or
    dvdsanta, can not keep extra material
    or
    dvd2svcd, can not keep extra material (only NTSC to PAL?)
    or
    numenu4u, including extra material but requires sonic scenarist or muxman(only in beta mode)
    You must rip the dvd to hd first with dvddecrypter. Rip all files from the DVD.
    Don't Hate The Player, Hate The Game.
    Jun 2005
    Oakland
    or
    or
    or
    or
    That's the point, do you really think that i have this program? i mean honestly? i don't have Sonic Scenarist, i don't even have $5,000 to get it for crying out loud.. I asked was there a way to do what i wanted, and the other guy said yes, but it's very complex.. What exactly is complex? I wasn't sent a guide or anything, just links to programs..
  6. That's the point, do you really think that i have this program? i mean honestly? i don't have Sonic Scenarist, i don't even have $5,000 to get it for crying out loud.. I asked was there a way to do what i wanted, and the other guy said yes, but it's very complex.. What exactly is complex? I wasn't sent a guide or anything, just links to programs..
    What do you want, someone to hold your hand or do it for you? Standards conversions are difficult to do properly and take time, knowledge and skill.
    So for crying out loud do some reading. There is no "Standards Conversion for Dummies" book which sounds like what you are looking for.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    we do not have guides for everything...yet...
  8. buy a cheap player who does the conversion, like cyberhome.
    too much work
    Jun 2005
    Oakland
    Damn, I come to "VIDEOhelp".com to get some HELP about a VIDEO problem, and people act as if i'm asking how many atoms are in the Sun.. Obviously i am gonna look for the simple way before I have to read 1 million threads on different sites on the subject.. If there is no guide, you shouldn't of even responded, it isn't that serious, i'll figure it out..
    Obviously these forums aren't for helping then, i guess they are for providing links and reffering to other sites that actually knows more on the subject. wow, i ask a question and can't even get an answer, just people getting offended because they can't explain to me..
  10. You'll need to demux the TS older and extract each menu seperately. at this point you convert each menu in a format which works for your authoring application. You would have to reauthor the title.
  11. I researched this and gave up. Too many steps and time consuming. You're better off getting a standalone dvd recorder and feeding a dvd player in it that does PAL, you also might need a macrovision blocker unless you hack your dvd player to play macrovision free (see dvd player reviews for more info)
  12. Either do the recommended thing and get a multi-format DVD player or...
    Buy the DVD in NTSC format that you downloaded.
  13. Video Restorer lordsmurf's Avatar
    Originally Posted by sonofisis
    Damn, I come to "VIDEOhelp".com to get some HELP about a VIDEO problem, and people act as if i'm asking how many atoms are in the Sun.. Obviously i am gonna look for the simple way before I have to read 1 million threads on different sites on the subject.. If there is no guide, you shouldn't of even responded, it isn't that serious, i'll figure it out..Obviously these forums aren't for helping then, i guess they are for providing links and reffering to other sites that actually knows more on the subject. wow, i ask a question and can't even get an answer, just people getting offended because they can't explain to me..
    Quit being a smart ass.
    What you want to do is not easy, never has been, never will be. What you are asking is very much indeed on par with something like "how many atoms are in the sun" (which by the way, there are several very good theories, but that too takes reading to learn more on it).
    The "easy way" is to either buy the NTSC version (cost of DVD), or if no NTSC version exists, get a player that can play PAL DVDs (as low as $35).
