I just bought a new computer which is much faster than my old one. it has windows XP, and I am using Hauppage WinTV card. I have checked all of the settings in the volume control, the audio plays while I watch TV, but when i capture it does not record the sound. I have it set up just like I did with the old machine, but the audio is not recording. Is this an XP thing or am I overlooking something. I have tried VDub, Cineplayer, and The XP software, and I get the same result with each one. any suggestions?
Hey I had the same problem when I installed my XP. It worked fine when I had WIN 98 but with XP I cant record sound either. Im going to reinstall my WIN 98. I know it works.
Boxingjunkie -
Have you connect audio out from wintv to sound card line in ?
Another problem I have. I canīt capture above 352x288.
Format is not supported. Probably the latest winxp driver fault. -
there are some new drivers out for happauge cards and Windows xp, I posted the site in the forum earlier this week it is at:http://www.windrivers.com/
try there, and also try connecting your audio directly into your line in and not going through the video card, this will tell you if the problem is in the video drivers or the soundcard drivers. Don't give up so fast, fix your problem you will be much happier with the stability of windows XP. -
I had same problem using any editing program,later i played with C-Media mixer,i knew i was using Wave for audio and wave was shut off,so finally after few sleeples nites I got sound,but i was disapointed again-i have a slight delay of sound when playing with video
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 22:56 -
Capturing HD From Another Computer's HDMI Out
By brandondrury in forum Capturing and VCRReplies: 20Last Post: 15th Mar 2011, 15:52 -
Audio Capturing from Computer
By Tahlos in forum AudioReplies: 11Last Post: 29th Nov 2010, 19:42 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 01:06 -
Capturing footage without a computer
By monkeybrains in forum Capturing and VCRReplies: 5Last Post: 22nd Sep 2007, 15:12
