ok all i'll make this quick i have an avi file thats a little pixelated and want to clean it up how can i do this also would cce be able to do this so i can put on dvd, are there any guides for noobs to start with, thank you again.
CCE is an encoder, not a filter. You can filter with VirtualDub/AviSynth, frameserve to CCE for DVD mpg encoding.
/Mats -
Use TMPGenc Plus. It will encode to DVD format (need to author after though) and you can use filters to tidy up and variable bitrate 'may' take away alot of the pixelating.
Here's a guide on frameserving with Virtualdub: https://www.videohelp.com/virtualdubframeserve.htm
You load your AVI into VD, select filters and frameserve the results to CCE. It's not that difficult once you have it set up.
This may not cure pixelation, if it's caused by too low of bitrate on the AVI. But it can probably make it look a little better. VD filters can also do many other things. There are dozens of them available. VD is one of the best AVI tools out there. If you're not familiar with using it, well worth learning.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 21:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 13:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 15:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 20:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13
