I've looked at some other articles but am still uncertain about this.
After exporting to MPEG-2 from Premiere using BBmpeg, I have a file that Ulead DVD Movie Factory 2 will send to DVD without re-encoding (so I'm not losing any more quality).
However, DVD Movie Factory *does* multiplex the audio/video before burning...is this a step I should be eliminating when the file was originally encoded? Am I losing any quality by this?
(In the past I had exported to .m2v and .mp2 files, but then DVD Movie Factory didn't seem to recognize them so I started going this route.)
If I understand the question correctly, Ulead DVD Movie Factory will first split the audio from the MPeg video and then build the multiplexed VOB file.
http://www.kiva.org/about -
Yeah...which I *think* is okay, and isn't re-encoding anything (because it has a separate process for "re-encoding" it goes through if it needs to, and it isn't doing that part), but I'm not quite sure *shrugs*
Basic question on MPEG-2 multiplexing
By nharikrishna in forum Authoring (DVD)Replies: 7Last Post: 2nd Feb 2011, 23:32 -
creating many small clips w/ mpeg ts file
By Funkymoses in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 12:53 -
creating small mpeg with delay between frames
By nighthawk2018 in forum Newbie / General discussionsReplies: 11Last Post: 30th Dec 2009, 10:56 -
Hauppauge PVR-250 creating corrupt MPEG file
By jedi34567 in forum Capturing and VCRReplies: 2Last Post: 16th Sep 2009, 00:53 -
Creating MPEG 4 Clips
By travelerkgd in forum MacReplies: 6Last Post: 8th Nov 2007, 23:29
