I converted some AVIs to MPEG using DIKO then authored them onto a DVD using TMPGEnc DVD Author everything seemed to be going fine until I played it in my DVD player, there is lots of green blocks and distortiony stuff. When I play the DVD on my computer its fine. Did I do something wrong or is it just my player. My DVD player says it can play MPEGs but it was pretty cheap so I'm hoping I may just need to get a new player? Thanks
Couple of things maybe:-maybe the player does not like the brand of discs; cheap media/bad batch; maybe you burnt it too quick and the dvd players laser finds it hard to read the data and finally it maybe a smudge/fingerprint or something on the underside of the disc before you burnt the film.
Offline
Forgive the ignorance because i'm still a relative freshman at this myself even 3 yrs in, but how could it be a codec problem? If it was, wouldn't it all be out of wack, i.e disc and file on HD if it was a codec issue?
He's encoded and burnt to disc yet the problem as only manifested itself on his home dvd player as it plays perfect on his PC (from disc and not HD).
This is more for the want of my further knowledge rather than trying stir up a debate.
Distortion in audio
By carlmart in forum AudioReplies: 2Last Post: 3rd May 2011, 14:59 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 17:13 -
Distortion when played on TV
By tomhopkins in forum Authoring (DVD)Replies: 4Last Post: 18th Jul 2009, 16:36 -
Distortion in FCP
By Daniel Corcoran in forum MacReplies: 7Last Post: 27th Jun 2008, 15:58 -
So much noise/distortion :(
By Lee82 in forum Capturing and VCRReplies: 1Last Post: 23rd Aug 2007, 01:14
