I have benn using to make DVD's for a few weeks now. I went to make one today and a error popped up saying Burn Failed. I will copy the log into the post. I have also supplied a screenshot of the message.
[18:42:27] ExpressUI Running NeroVision Express 3 Version: 3.1.0.0
[18:42:31] DVDEngine Running DVDEngine version: 3.0.1.96
[18:42:31] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:42:31] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:42:31] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:42:31] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:42:36] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:42:36] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:42:36] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:42:36] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:42:36] MMTools adding c:\Documents and Settings\Dan\Desktop\Program.Files\Movies\The Matrix Reloaded.mpg [0..4045266944] video/0
[18:42:36] MMTools --- used source filters ---
[18:42:36] MMTools {33E02305-BA15-4361-BA65-13536F7A56B7} - GCAsyncSrc
[18:42:36] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[18:42:36] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[18:42:36] MMTools file type MPEG2 - video
[18:42:36] MMTools --------------------
[18:42:41] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:42:41] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:42:41] DVDEngine BEGIN: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:42:41] DVDEngine END: IDVDVideoSessionImpl - ~IDVDVideoSessionImpl
[18:42:42] MMTools adding c:\Documents and Settings\Dan\Desktop\Program.Files\Movies\The Matrix Reloaded.mpg [0..4045266944] audio/0
[18:42:43] MMTools --- used source filters ---
[18:42:43] MMTools {33E02305-BA15-4361-BA65-13536F7A56B7} - GCAsyncSrc
[18:42:43] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[18:42:43] MMTools {138130AF-A79B-45D5-B4AA-87697457BA87} - Nero Digital Audio Decoder
[18:42:43] MMTools file type MPEG2 - audio
[18:42:43] MMTools --------------------
[18:42:43] MMTools adding cached c:\Documents and Settings\Dan\Desktop\Program.Files\Movies\The Matrix Reloaded.mpg [0..4045266944] video/0
[18:42:52] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[18:43:07] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[18:43:14] ExpressUI Burn process started by user.
[18:43:14] ExpressUI Destination: PHILIPS DVDR1640P
[18:43:14] ExpressUI Directory for temporary files: C:\DOCUME~1\Dan\LOCALS~1\Temp
[18:43:14] ExpressUI ------<NeroVision Project Information>--------
[18:43:14] ExpressUI --- Project type: DVD-Video
[18:43:14] ExpressUI --- Project video options ---
[18:43:14] ExpressUI Video mode: PAL
[18:43:14] ExpressUI Aspect ratio: Automatic
[18:43:14] ExpressUI Quality: Automatic
[18:43:14] ExpressUI Resolution: Automatic
[18:43:14] ExpressUI Sample format: Automatic
[18:43:14] ExpressUI File type: MPEG-2
[18:43:14] ExpressUI Audio format: Stereo
[18:43:14] ExpressUI Encoding mode: Fast Encoding (1-Pass)
[18:43:14] ExpressUI --- Project space information ---
[18:43:14] ExpressUI Used disc space: 4.34 GB
[18:43:14] ExpressUI --- Project contents ---
[18:43:14] ExpressUI Number of titles: 1
[18:43:14] ExpressUI 1. The Matrix Reloaded (Video Title, 6h 54m 18s)
[18:43:14] ExpressUI Aspect ratio: 4:3
[18:43:14] ExpressUI Quality: Standard play (5073 kbps)
[18:43:14] ExpressUI Resolution: 720 x 576 (CCIR-601 D1)
[18:43:14] ExpressUI Audio SmartEncoding ratio: 100.0 %
[18:43:14] ExpressUI Video SmartEncoding ratio: 98.2 %
[18:43:14] ExpressUI --------<End of Project Information>----------
[18:43:14] DVDEngine BEGIN: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:43:14] DVDEngine END: IDVDEngineManagerImpl - CreateDVDVideoSession
[18:43:14] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[18:43:14] DVDEngine ..Session callback registered...
[18:43:14] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[18:43:14] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterApplicationService
[18:43:14] DVDEngine ..Application service registered...
[18:43:14] DVDEngine END: IDVDSessionBaseImpl - RegisterApplicationService
[18:43:14] DVDEngine BEGIN: IDVDSessionBaseImpl - BeginDiscAccess
[18:43:14] DVDEngine ..Access mode=read/write
[18:43:14] DVDEngine ..Flags=0
[18:43:14] DVDEngine ..Write speed=11080 KB/s (8x)
[18:43:14] DVDEngine ..Medium type=DVD-R
[18:43:14] DVDEngine DVD format is 1
[18:43:15] DVDEngine Supported Access Modes: 0x00000001
[18:43:15] DVDEngine **BEGIN: IDVDSessionBaseImpl - Update HCB state
[18:43:15] DVDEngine **END: IDVDSessionBaseImpl - Update HCB state
[18:43:15] DVDEngine END: IDVDSessionBaseImpl - BeginDiscAccess
[18:43:15] DVDEngine BEGIN: IDVDVideoSessionImpl - Prepare
[18:43:15] DVDEngine ..BAO activated
[18:43:15] DVDEngine **BEGIN: _DVDVideo - Prepare
[18:43:15] DVDEngine ..VTS_Ns=1...
[18:43:15] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VMG
[18:43:15] DVDEngine ...VMGM_VOBS_exist = false
[18:43:15] DVDEngine ****END: _DVDVideoBase - Prepare VMG
[18:43:15] DVDEngine ****BEGIN: _DVDVideoBase - Prepare VTS#1
[18:43:15] DVDEngine ...VTSM_VOBS_exist = false
[18:43:15] DVDEngine ******BEGIN: VTSTT_VOBS#1 - Process Create
[18:43:15] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:43:15] NeroVision Analyze video stream
[18:43:15] NeroVision Seg. | frames | weight | volume
[18:43:15] NeroVision ------+---------+--------+--------
[18:43:15] NeroVision 0 | 607281 | 1 | 607281
[18:43:15] NeroVision 1 | 107 | 1 | 107
[18:43:15] NeroVision 2 | 2987 | 1 | 2987
[18:43:15] NeroVision 3 | 11090 | 1 | 11090
[18:43:15] NeroVision total : 621465
[18:43:15] DVDEngine **********BEGIN: _VOBS - _M_analyze_cnv_input
[18:43:15] DVDEngine ...Duration 248586000000
[18:43:15] DVDEngine ..._streamtime_frame_duration is 400000
[18:43:15] DVDEngine ...Stream 0 is 'Video'
[18:43:15] DVDEngine ...Stream 1 is 'Audio'
[18:43:15] DVDEngine **********END: _VOBS - _M_analyze_cnv_input
[18:43:15] NeroVision Estimate Size
[18:43:15] NeroVision +-------+------+--------+----------+---------
[18:43:15] NeroVision |Stream | Seg. | UnComp.| Duration | Size (KB)
[18:43:15] NeroVision | 0 | 0 | 0 | 24291.24 | 2777428
[18:43:15] NeroVision | 0 | 1 | 1 | 4.28 | 2874
[18:43:15] NeroVision | 0 | 2 | 0 | 119.48 | 2923
[18:43:15] NeroVision | 0 | 3 | 1 | 443.60 | 274929
[18:43:15] NeroVision | 1 | 0 | 0 | 24293.48 | 1138757
[18:43:15] NeroVision | 1 | 1 | 0 | 565.12 | 26490
[18:43:15] NeroVision total data size : 4324991763 bytes
[18:43:15] NeroVision multiplexed size : 4656930816 bytes
[18:43:15] MMTools adding cached c:\Documents and Settings\Dan\Desktop\Program.Files\Movies\The Matrix Reloaded.mpg [0..4045266944] video/0
[18:43:16] MMTools adding c:\Documents and Settings\Dan\Desktop\Program.Files\Movies\The Matrix Reloaded.mpg [4045266944..4075915268] video/0
[18:43:16] MMTools --- used source filters ---
[18:43:16] MMTools {33E02305-BA15-4361-BA65-13536F7A56B7} - GCAsyncSrc
[18:43:16] MMTools {A336CD3B-599C-4F70-A34D-E88EDE4B64C3} - Nero Splitter
[18:43:16] MMTools {C0BA9CF8-96E0-4C34-B5DE-E92C3FC05ED6} - Nero Video Decoder
[18:43:16] MMTools file type MPEG2 - video
[18:43:16] MMTools --------------------
[18:43:21] DVDEngine ********END: _VOBS - Process VOB
[18:43:21] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
[18:43:21] DVDEngine ****END: _DVDVideoBase - Prepare VTS#1
[18:43:21] DVDEngine **END: _DVDVideo - Prepare
[18:43:21] DVDEngine ..Estimated size (overall)=4.34 GB
[18:43:21] DVDEngine ..Estimated duration (overall)=23 min 30 sec
[18:43:21] DVDEngine END: IDVDVideoSessionImpl - Prepare
[18:43:21] DVDEngine BEGIN: IDVDSessionBaseImpl - GetDiscCaps
[18:43:21] DVDEngine ..Caps=DSCCAP_VLMNM_UDF | DSCCAP_VLMNM_ISO9660
[18:43:21] DVDEngine END: IDVDSessionBaseImpl - GetDiscCaps
[18:43:21] DVDEngine BEGIN: IDVDSessionBaseImpl - SetLabel
[18:43:21] DVDEngine Volume name (ISO9660) = "DVD"
[18:43:21] DVDEngine END: IDVDSessionBaseImpl - SetLabel
[18:43:21] DVDEngine Volume name (UDF) = "DVD"
[18:43:21] DVDEngine BEGIN: IDVDVideoSessionImpl - GetDiscContent
[18:43:21] DVDEngine **BEGIN: _DVDVideo - Fill FileSystemDescContainer
[18:43:21] DVDEngine ..File: 'VIDEO_TS\VIDEO_TS.IFO' (VMGI), location={undefined}, size=8.00 KB (8,192 bytes)
[18:43:21] DVDEngine ..File: 'VIDEO_TS\VIDEO_TS.BUP' (VMGI), location={undefined}, size=8.00 KB (8,192 bytes)
[18:43:21] DVDEngine ..File: 'VIDEO_TS\VTS_01_0.IFO' (VTSI), location={undefined}, size=214 KB (219,136 bytes)
[18:43:21] DVDEngine ..File: 'VIDEO_TS\VTS_01_1.VOB' (VTSTT_VOBS), location={undefined}, size=4.34 GB (4,656,955,392 bytes)
[18:43:21] DVDEngine ..File: 'VIDEO_TS\VTS_01_0.BUP' (VTSI), location={undefined}, size=214 KB (219,136 bytes)
[18:43:21] DVDEngine **END: _DVDVideo - Fill FileSystemDescContainer
[18:43:21] DVDEngine END: IDVDVideoSessionImpl - GetDiscContent
[18:43:21] NeroAPI Burn process started at 8x (11,080 KB/s)
[18:43:21] DVDEngine BEGIN: IDVDVideoSessionImpl - CreateDisc
[18:43:21] DVDEngine **BEGIN: _DVDVideo - Create
[18:43:21] DVDEngine ****BEGIN: Create - VTSTT_VOBS#1
[18:43:21] DVDEngine ******BEGIN: VTSTT_VOBS#1 - Process Create
[18:43:21] DVDEngine ********BEGIN: _VOBS - Process VOB
[18:43:21] NeroVision Analyze video stream
[18:43:21] NeroVision Seg. | frames | weight | volume
[18:43:21] NeroVision ------+---------+--------+--------
[18:43:21] NeroVision 0 | 607281 | 1 | 607281
[18:43:21] NeroVision 1 | 107 | 1 | 107
[18:43:21] NeroVision 2 | 2987 | 1 | 2987
[18:43:21] NeroVision 3 | 11090 | 1 | 11090
[18:43:21] NeroVision total : 621465
[18:43:21] NeroVision Set Preview Channel
[18:43:22] DVDEngine ...New VOB 1
[18:43:22] DVDEngine ..>VOB: VOBN=1, VOB_IDN=1, SA=0, VOB_V_S_PTM=29612
[18:43:22] DVDEngine ...New CELL 1
[18:43:22] DVDEngine ....>Cell: C_IDN=1
[18:43:22] MMTools adding cached c:\Documents and Settings\Dan\Desktop\Program.Files\Movies\The Matrix Reloaded.mpg [0..4045266944] video/0
[18:43:22] MMTools adding cached c:\Documents and Settings\Dan\Desktop\Program.Files\Movies\The Matrix Reloaded.mpg [4045266944..4075915268] video/0
[18:43:22] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[18:43:37] GCCore The following operation did not finish in the past 15 seconds: Graph control (Stream segment)
[18:43:37] GCCore The following operation did not finish in the past 15 seconds: Receive sample (GC Sink)
[18:43:37] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[18:43:38] GCCore The following operation did not finish in the past 15 seconds: Receive sample (GC Sink)
[18:43:41] GCCore WARNING: Operation locked for more than 15 seconds: GCSink (259)
[18:43:52] GCCore The following operation did not finish in the past 15 seconds: Graph control (Stream segment)
[18:43:52] GCCore The following operation did not finish in the past 15 seconds: Receive sample (GC Sink)
[18:43:52] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[18:43:53] GCCore The following operation did not finish in the past 15 seconds: Receive sample (GC Sink)
[18:43:56] GCCore WARNING: Operation locked for more than 15 seconds: GCSink (259)
[18:44:07] GCCore The following operation did not finish in the past 15 seconds: Graph control (Stream segment)
[18:44:07] GCCore The following operation did not finish in the past 15 seconds: Receive sample (GC Sink)
[18:44:07] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[18:44:08] GCCore The following operation did not finish in the past 15 seconds: Receive sample (GC Sink)
[18:44:11] GCCore WARNING: Operation locked for more than 15 seconds: GCSink (259)
[18:44:15] DVDEngine ********END: _VOBS - Process VOB
[18:44:15] DVDEngine ******END: VTSTT_VOBS#1 - Process Create
[18:44:15] DVDEngine ****END: Create - VTSTT_VOBS#1
[18:44:15] DVDEngine **END: _DVDVideo - Create
[18:44:15] DVDEngine END: IDVDVideoSessionImpl - CreateDisc
[18:44:22] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
[18:44:23] NeroAPI Burn process failed at 8x (11,080 KB/s)
[18:44:23] DVDEngine BEGIN: IDVDSessionBaseImpl - EndDiscAccess
[18:44:23] DVDEngine ..Flags=0
[18:44:23] DVDEngine **BEGIN: _MediaAccess::Release ()
[18:44:23] DVDEngine ****BEGIN: _MediaAccess::~_MediaAccess ()
[18:44:23] DVDEngine ****END: _MediaAccess::~_MediaAccess ()
[18:44:23] DVDEngine **END: _MediaAccess::Release ()
[18:44:23] DVDEngine END: IDVDSessionBaseImpl - EndDiscAccess
[18:44:23] DVDEngine BEGIN: IDVDSessionBaseImpl - RegisterCallback
[18:44:23] DVDEngine ..Session callback unregistered...
[18:44:23] DVDEngine END: IDVDSessionBaseImpl - RegisterCallback
[18:44:37] GCCore The following operation did not finish in the past 15 seconds: Grab still image (AVStillSource)
Did you have the trial version?, maybe it ran out of time.
Quality is my policy. -
Yeah i have the trial version but it hasnt ran out yet. I still have another 3 weeks.
although i am no expert in reading such error logs, it does look liike there is something very not quite right in that lot.
It appears that you are trying to do the whole process;
file --> demux --> re-muxed --> DVD compliant --> burn to disc
ALL in one application and in fact one button press.
While this may well work well some of the time, many people here (me included) would recommend that you use a number of different programs to get the same out come.
What format is the original file? as it would appear to be a MPG, which dont naturally come from DVD's.
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 06:38 -
Question about new type of Nero 6 burn error
By jimdagys in forum DVD RippingReplies: 13Last Post: 29th Jun 2009, 00:22 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 10:02 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 20:58 -
Error when dvd shrink trys to burn thru nero automatically
By themow in forum Video ConversionReplies: 1Last Post: 13th Oct 2007, 13:12
