  1. I'm new at DVD authoring. I just purchased Encore DVD and started messing with it. When I edit a menu or button it goes into Microsoft Picture It 9 software instead of Photoshop CS. I can't find a setting to change this behaviour. Can someone help?
  2. I had the same problem before, but my photos went to ACDsee (which is my picture browser) instead of PS. The problem was corrected when I changed the file association in ACDsee; de-select the file association of psd or jpeg with ACDsee.
    I hope this will help
  3. Thanks for the reply. I did what you said but I do not show Photoshop CS as a program to use for .psd files. It shows Paint shop 7 and old version of Photoshop that I had loaded last year (Starter Edition 2.0). I did change it to Paintshop and indeed Encore edits in Paintshop BUT I need Photoshop CS.... Any other ideas are greatly appreciated.
  4. Can I use Photoshop CS as a standalone program even though it's integrated within Encore? If so, I cannot find executable.
  5. Originally Posted by XMando
    No, you need to install Photoshop CS.
    Try Photoshop CS2 free for 30 days 329.1MB
    =>> http://www.adobe.com/products/tryadobe/main.jsp#product=39
