whats the best encoder that is optimize to dualcore? I have intel 2.8 dualcore which I want to get the most milage out of it for xvid encoding, in the encoder options the thread number is off so I don't know what to do...
thanks
I think there has been some work done under linux. If you are running windows then I'm afraid that XviD's core simply isn't setup for dual core. None of the XviD devs have dual core setups, so no work has been done under windows.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Best xvid encoder
By sanosuke in forum Video ConversionReplies: 4Last Post: 6th Oct 2010, 09:20 -
Config XviD Encoder to control size
By kevin182h in forum Video ConversionReplies: 6Last Post: 27th Feb 2008, 19:02 -
XVID and AVS Media Encoder
By jwfc in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2007, 18:23
