  1. Hello,
    Been using the ATI AiW 9800 Pro with ATI's MMC software for capturing MPEG-2.
    For capturing standard VHS, what would be the lowest bitrate I should capture at, but still retain the BEST quality.
    Likewise, I am using Pinnacle Studio 9 for making DVDs. It also has options for Bitrate when making the finalized DVD. Range is 3000-7500.
    Are these related at all? If I only capture at 5MB, would it make sense to set Pinnacle's bitrate to 7500 ?
  2. Pinnacle 9 doesnt re-encode my video. I dont think :0
    Once I capture MPEG-2 at 720x480 with ATI MMC, it takes less than an hour compile and burn the video onto DVD with Pinnacle Studio.
    Believe it or not, I have already read all of those, and I am still unclear regarding the bitrates. If I capture at a higher bitrate, should I also tell studio to use the higher rate.
    I guess I am just looking for the best quality settings for standard VHS.
  3. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    If it suggests a new bit rate :
    then its re encoding your clips.
    Use a better program if you can afford it!
    obviously, if you encode at 5, you can't get more quality than that in any
    later step.
    suggestionsDVD ARCHITECT
    TMPG DVD AUTHOR
    Read this:
    http://www.digitalfaq.com/dvdguides/capture/intro.htm#mpegbitrate
    Extrapolate from this:
    http://www.digitalfaq.com/dvdguides/capture/understandsource.htm#analogsource
    To spell it out for you: 352x480 and 3.0 to 5.0Mb/s range VBR (3000k-5000k). Maybe as low as 2.0 to 2.5 on animation.
