how do i do this? what program should i use? i tried tmpenc but it doesn't work.
Results 1 to 20 of 20
Look to the left side of this site with different topics. Go to: How to>>Author. Yes, it tells you everything there.
i've tried everything said on this site. it still won't let me convert the mpeg-1 file into an mpeg1 vcd file. or are all mpeg-1 files vcd compliant?
If your looking for a vcd extension there is no such thing, the extension will still be mpg only it will be a vcd compliant MPG file.
No, not all MPEG 1's are VCD compliant. When you say TMPGEnc doesnt work, what do you mean? Did you try using File-> MPEG Tools. Go to the Merge & Cut tab and add your .mpg. Normally you would right click and edit it but if you simply leave the entire file entact and save it using that tabs pull down menu MPEG-1 Video CD setting you should be all set
i tried smokin's tmpegenc solution but it outputs a file that just stops as soon as it starts.
uhmm.. VCD is an mpeg 1 at 1150 kb/sec 352x240 (talking ntsc) at either 23.976 fps or 29.97 fps
audio - 224 kb/sec mpeg-1 layer 2
anything else isnt to vcd spec.. it also must be streamed the right way. basically if you have an mpeg1 at the above specs and nero rejects it it probably isnt streamed right. just have to demultiplex and multiplex to mpeg -1 vcd . tmpgenc does that quite nicely in one step
what doyou mean doesn't work? what message are you getting, what is it doing? need more info.
if your mpeg-1 is at vcd specs but just not streamed right.. you goto tmpgenc - file - mpeg tools multiplex (not the basic one) load the mpeg then type in the new output file name you want . make sure type is set to mpeg-1 videoCD and hit start... takes about 10 seconds or so (depending on cpu speed) and voila.. shove it in nero and burn baby burn.. if nero doesnt take it at this point then recheck the specs.
nikmagid, you said "i tried smokin's tmpegenc solution but it outputs a file that just stops as soon as it starts."
What I beleive is your mpeg file is may be mpeg-2. Can you double check whether the file is mpeg-1 or mpeg-2
Download MPEGProperties from http://www.medialab.se/mpgp_100.zip
Isntall and run. Let me know
if ti goes up to video cd, does that means it is a vcd already? what are the other lines on the program? what about if it goes above video cd or below?
Can you open your mpeg file using windows media player? Are you able to see the video?
then ones i made using tmpenc i cannot see the video. the ones i download open up in media player fine with no problems. is there a difference between .mpg and .mpeg files? i have both.
This means what you made with tmpenc is mpeg-2 file (you might have choosed SVCD template).
the original is mpeg-1.
Open a nero. try to burn original mpeg-1 file. If it accepts good. If not re-encode you mpeg-1 then burn.
Good Luck
onelast question. when using mpeg properties, how can you tell if the mpeg is a vcd and if it isn't. if it isn't, how can you tell what type of mpeg it is?
hey i figured it out for myself. what o dp is extract the audio from the mpeg file using graphedit into a wav file. i then convert the mpeg into an movie only divx avi without sound using virtualdub. i then encode it into a vcd usin tmpgenc. it works!!!!!!!! thanks for all of your help everyone.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40
