I've got a (european) Sony KV-28DS60U tv, NTSC compatible in, with Scart connectors.
I'm trying to connect it to a (u.s) Sony RDR GX7 dvd recorder, converted to 240v, which has YUV out....
Using a Profigold PGV372 cable, all i get on the screen are black and green, moving, diagonals. The diagonals change slightly when you play a disc, presumably because some signal is being picked up.
Anyone have a clue how i can get the YUV/ Scart connection to work (vid/audio phono connection works ok, but i got a YUV cable, so i'm not giving up yet!).
ta chuck,
domino -
Have you tried both SCART sockets on the TV? My Sony KV-28DL11 has two SCARTs, one can deal with S-Video, the other can deal with RGB. The cable you are using is an RGB cable, is that what your DVD player is outputting?
thanks for the input richard,
the tv has 3 scarts, one capable of RGB - that's the socket with the diagonals, using either of the other sockets doesn't show anything on screen.
the dvd def has RGB (YUV) outputs.
some RGB cables seem to have a 4th 'sync' connector, but as far as i can see, there's nothing on the dvd to plug that in to, so i guess it shouldn't be needed to make a connection (or should it ?).
the guy where i bought the cable from suggested the circuitry in the dvd, it been made for the u.s. market, isn't compatible with scart. could that be a possibility? anyway around that - if it's correct?ta chuck,
domino -
Green and black diagonal lines (often with a weak black and white image in the background) are what I get if I put an NTSC source into a PAL display so it sounds like the TV cannot work out that the input is NTSC. It may be that what is coming out of the DVD player isn't compatible and the TV isn't recognising it.
May be time to spend £30 on a new DVD player.
JPEG to YUV
By mma238 in forum Video ConversionReplies: 20Last Post: 3rd Apr 2011, 11:53 -
Problem in reading a YUV file ... values are 205 !!
By krao in forum Newbie / General discussionsReplies: 17Last Post: 31st Jan 2011, 03:35 -
AVS to YUV
By fidogenial in forum Video ConversionReplies: 1Last Post: 21st Oct 2010, 21:53 -
PC To Scart
By simonm95 in forum DVB / IPTVReplies: 5Last Post: 19th Jul 2009, 12:54 -
Problem capturing from VHS recorder via SCART
By Freebird in forum Capturing and VCRReplies: 8Last Post: 29th Aug 2007, 13:18
