I've been reading much about tv tuner devices for two of my systems. One runs WinXP while the second XP Media Center. Well, it has become apparent that the more I read the more confused I get. From tuner, remote and software compatibility to performance...The questions seem to be never-ending.
One of the many reviews I've read:
MCE TV Tuner Roundup
I'm basically looking for a PVR with a remote (packaged or third-party). It will hook up into a cable box which has both coax and S-Video connections. Do the tuner software and remote really make a difference?...Or is it a matter of preference?
Here are the cards I'm considering:
ATI TV Wonder Elite Remote Control Edition PCI
Hauppauge 1042 PCI Interface Win TV150 PVR-MCE
Hauppauge WINTV-PVR-150 PCI
Hauppauge 980 ( WinTV-PVR-250 ) PCI Interface TV Tuner Card
eVGA 016-P1-NVTV-TX PCI Interface NVTV TV Tuner 16M SDR PCI
MSI Theater 550Pro MS-8621-010 PCI
Which cards should be a serious contender (eliminate or add if needed)? To work with the cable box, which software and remote do you recommend?...Or will the packaged versions work? Other factors I should consider?
WinTV-PVR 150
This come with 45 button Remote and IR Receiver/Transmitter and work with a few 3rdparty PVR software package.
SageTV, BeyondTV and GB-PVR
WinTV-PVR 150MCE or 500MCE
Come with FM tuner and REAL RCA Audio jack but no 45 button Remote and IR Receiver/Transmitter
So there for you need something like the USB-UIRT and work with any IR Remote and work with a lot 3rdparty PVR software package.
Theater 550 Pro aka TV Wonder ELITE
Nice but has a few problems
Run Hot which can be fix by add heatsink+fan
Audio vol way to low, to me it like 20 to 30% to low
Only well support under BeyondTV rigth now, Note I have not test GB-PVR or any other 3rdparty package. -
Thanks SHS for the reply.
Unless I'm mistaken, the Hauppauge 250 is also a discontinued product...So, I'll consider going with the 150. The GB-PVR seems to be highly recommended here so I'll take a look at that software. If it doesn't work for me I'll head straight to BeyondTV.
Will the packaged softare and remote work with the cable box? -
Author,
what card/setup did you end up choosing and how did it work out for you?
I have a question how to get hd quality on a tuner
By sdavis in forum Capturing and VCRReplies: 5Last Post: 16th Dec 2008, 15:52 -
Dual Monitor and TV Tuner question
By alanngray in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 14:22 -
TV Tuner S-Video Out Question
By fordguy in forum Newbie / General discussionsReplies: 6Last Post: 20th Mar 2008, 17:23 -
direct Tv question and tv tuner
By mohz in forum DVB / IPTVReplies: 3Last Post: 6th Jan 2008, 20:35
