I'd like to film my monitor so I can make a simple "how to" video for an elderly friend. (He can watch and follow along on his Mac).
Of course I have the flicker problem due to the refresh rate of the monitor and the frame rate on the video camera.
Can anyone suggest a way to reduce or stop the flicker?
I've tried various settings on my camcorder and tried using a program called "Screen Record"; which worked but which was very slow on my 867, and didn't prodcue the results I was after.
Many Thanks.
There are probably screen recording programs for the Mac like the ones for the PC.
If you use a NTSC video camera, slow your display refresh to 60 Hz (frames per second). It won't be perfect but the lines will move much slower with less flicker.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yes, slow the refresh rate of the monitor and see if you can find a setting on the camcorder which gives you a longer shutter speed. It depends very much on the specific model how much control you have. You might get some acceptable results.
Another option would be if your computer has a composite or S-video out. Then you could record the output onto a VCR. This would certainly look much better than trying to video a monitor, although I suspect it would still look startlingly bad.Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh? -
I believe a LCD screen flickers less or doesn't flicker at all to a video camcorder.
Snapz Pro should be a good app to grab video from the while screen or from a selected spot (AFAIR this could be a permanent spot on a screen or it could follow the pointer).
Feeding analog-out to a camcorder has also been mentioned. You should then adjust the screen to PAL/NTSC resolution for best results. -
Kinescope!
"I believe a LCD screen flickers less or doesn't flicker at all to a video camcorder. "
Do you want to try that one? -
Re-reading the original post, something I have done before is output my ATI AIW card to the tv and record to VHS.
Just use a large res (640x480) so everything can be read, none of that small stuff (1024x768, etc).Want my help? Ask here! (not via PM!)
Filming a Model Train
By railad in forum Off topicReplies: 3Last Post: 20th Apr 2012, 11:00 -
delete, yo
By hotmetaldobermans in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jun 2010, 08:05 -
Want to watch what I'm filming on a moniter while I'm filming it. Help!!!
By baer77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Feb 2010, 22:58 -
Computer Monitor Flicker Problem
By Xenon77 in forum ComputerReplies: 2Last Post: 7th Sep 2009, 16:15 -
Confused About Filming Permits
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 10th Apr 2008, 08:52
