I don't want to start a new thread , so i will ask it here and it will be useful for you and me . Who have the pinancle Av/DV ?
it seems good :
- Have the same chip than Canopus ADVC 50 , Philips SAA.... for Analog ->DIGITAL
- Can capture from analog using DV and MJPEG codec
- Full support nowdays
- Compatible with S.L
- Cheap
- Easy to find
I don't know if it have a audio input ...
What i like is the MJPEG , it is like the DC30 but i haven't the zoran chip.
Also i have tried to find a decent review in Google without success
What i want to know .....
- Dv and mjpeg is in realtime? (if it works with S.L , it must be ..)
- It have an audio input?
- Normally have A/v sync problems or tendency to drop frames?
- The drivers is WDM , VFW?
- Picture quality? is the same than the source? (that is what i want)
- I don't want to think that the MJPEG capture is a DV->MJPEG conversion
- Works with 4:2:0 and 4:1:1?
Thanks!
Results 31 to 37 of 37
LSI CHIP!
I think that it is an older model... maybe 8 deluxe..
New av/dv 9 :
I have the Pinnacle Studio AV/DV board, w/ ver 9 software.
(I don't use the software)
Mine is the Pinacle GmbH, (i) made in Germany board, with
the SAA7113h and ADV7179 chip, using the Pinnacle stamp
on the biggist chip (there are 3 chips only, on this board)
On my board, I think the revision number is 0407 in white.
This board is Analog only, and captures that way.. the best
way
It has three feature connections..
* Composite
* S-Video and
* DV (6 pin)
The capture is pure analog. Anything that is captured, can be
real-time encoded to other formats, pending codec availability.
That means, if you have a DV codec (encoder) you can capture
in real-time, to DV.
The reason it says, AD/DV is on account that it can accept
both Analog and Digital sources.
But, it will output to DV (ie, to your CAM in dv format)
For DV, you connect your DV CAM 's 4-pin plug to the CAM, and
the other end, 6-pin to the board. (This would be equivalent
to the iLO 's DV in) You plug you CAM into the 6-in of the board
and it will capture it in Analog format, not DV avi. That is
probably what you are thinking. It's purely an Analog capture
card.
But, I have not been able to get it to work, because it is
WIN 98SE minimum system requirements, and I'm on WIN98Gold
(I usually refer to it as Win98x) so, it sits on the shelf,
rotting way.. unless I can figure out how to get it to work
under win98x
That's about all I know, of the AV/DV board.
-vhelp 3494 -
Win98Gold...
vhelp, you must be the only person I know with this windows version....
I use W2K GR myself (and see no reason to "upgrade") -
It's one of the many ummm strange reasons why you gotta love vhelpOriginally Posted by SatStorm
So ...
no , dv only
deluxe vesion only
WDM , you can capture with VirtualVCR. I don't know if you can capture with virtualdub..
No , it isn't
Both
- Capture Pal60 signals?
i just purchased one , i will do a review when i get it
Need some advice on a capture card for Xbox 360!
By smitty260 in forum Capturing and VCRReplies: 7Last Post: 29th Feb 2012, 23:23 -
video capture card advice
By MikeClark in forum Capturing and VCRReplies: 3Last Post: 10th Nov 2011, 23:10 -
Newbie needs some advice - capture card so I can record several cameras?
By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 03:41 -
Advice needed for an Xbox 360 capture card.
By Bonno in forum Capturing and VCRReplies: 2Last Post: 23rd Oct 2010, 17:15 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 11:28
