This thread hasn't actually closed... what's up?
Results 331 to 340 of 340
My external subtitle is sync subtitle before remux, but after remux it's not sync & after reauthored the colours too dark. only about 30 minutes without problem but after that it's getting late...out of sync.
please help. thanks -
First, most of my experience has been in Closed Captions. But maybe there is something I stumbled onto the last time my captions drifted out of sync that may apply to your problem. In my case the problem was dropframe time code vs no dropframe timecode. This allowed about a frame a minute drift. So After 30 mins. you might be off 1 second. Regardless if that is the issue.. if the sync drift is constant there may be a solution similar to SCC tools CCADJ.EXE. Wish I could be more helpful.
thanks for your reply.
i've been try all subtitles, but it same problem.only about 30 minutes the subtitle sync perfect. or maybe it's because subtitle creator bug? -
Btw, how can i save the subtitle using subtitle creator with right colour or same with the movie subtitle...white colour, because after save to SUP my subtitle becomes too dark, i want it at normal colour. thanks
Is Subtitle Tool still available? I cant seem to find it. If anyone could send me a link that would be great.
How to add new subtitle option in menu
By diamondback in forum SubtitleReplies: 2Last Post: 3rd Jun 2010, 06:14 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 03:01 -
Add subtitle, keep menu/extras
By canaQ in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 06:36 -
How to insert *.srt subtitle and add button to DVD menu?
By goodvd in forum SubtitleReplies: 1Last Post: 17th May 2008, 22:04 -
Tracing which PGC is played when a DVD menu button is clicked
By Cheekie_Moonkie in forum Authoring (DVD)Replies: 3Last Post: 5th Sep 2007, 15:29
