I have a .mpg captured from my cable box using CapDVHS. I want to create a DVD from it. I have the latest Nero Ultra. There is a "line" or some kind of noise in the top of the frames. I would like a suggestion for the easiest tool to remove this. I have DGIndex and found the "clipping" feature which does get rid of the problem area but got seriously screwed up trying to deal with that apps output files.
I really appreciate your help here! I'm so frustrated the Cat will not come within 10 feet of me...
Wolf
Poor kitty. I have a stray cat that doesn't like to stay inside. Gets mad at me and meows crazy.
Anyway analog signals will always have some noise on either or all of the sides of capture. Especially VHS, which has some noise on bottom of the frame. I would not waste time cropping. This noise will never be seen on any TV, because it will be in the overscan area. If you still want to remove it, any mpeg2 encoder has "mask" option. TMPGEnc has this option. Load your file into it, and select Mask option. -
Normal to have that at the top of the screen, It is only seen on the computer. If your target is DVD for TV, then leave it, it won't be seen. If your target is computer then you'll have to process to get rid of it.
I myself never bother with it since my target is DVD for viewing on TV set and I'll never see it due to Overscan.
Cheers -
Merlin is a Champagne Mink Tonkinese. He is concerned because he has noticed I am making lots of angry sounds and seem to have lost control of my motor control. I have been unable to explain to him I am merely frustrated by my inability to make this stuff do what I want.
TMPGEnc gets an error when trying to open the .mpg. It says it can only open the audio portion.
Wolf -
OMG! I just spent the most of the day trying to fix something that won't even affect the final DVD! The next time I am looking for a new hobby I think I'll try something simpler.
Like cold fusion.
Wolf -
FYI: What you are seeing is the bottom of the vertical blanking interval. The last lines contain closed caption data, other data and transmission test signals.
http://www.kiva.org/about -
Thanks! After all this the DVD I burned has artifacts everywhere.
The file plays without them on my PC.
Back to the drawing board.
Wolf
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
Blinking line of thin white dashes at top of screen
By turbines in forum Capturing and VCRReplies: 15Last Post: 25th Apr 2010, 23:05 -
Can't Get Rid of Noise
By EmpireStrikesBack198 in forum RestorationReplies: 6Last Post: 9th Mar 2010, 07:21 -
Weird horizontal line on top of the black area when playing movies(screen).
By Nitrius in forum Software PlayingReplies: 2Last Post: 23rd Aug 2008, 14:12 -
VCR Overscan Issues ("jittery" line at top of screen)
By jcm0320 in forum Capturing and VCRReplies: 14Last Post: 24th Aug 2007, 14:56
