I converted a VHS into DVD and burnt with DVDMF4 as always, in NTSC half D1 with LPCM audio (usually I do MPEG-1 layer 2, but I had audio sync problems when trimming)... It worked great in my dvd player, but in LG5822N the owner told me that nothing was displayed...
So, I suspect the audio format (LPCM) is the problem or the 8X Smartbuy media... Anyone can help me to figure it out? Does 5822N support LPCM?
Thanks in advance.
Fredİ
Brazil
I don't think that the LG 5822N is sold in the US. The don't even mention it on LG's Brazilian site. I doubt if you'll get much help on it here. But you never know.
thank you for your help, but I burnt another media (Sony DVD-RW) with same LPCM audio and LG recognized it... So, the problem is only the media...Originally Posted by ebenton
thank you. Problem solved.
Fredİ
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
DVD to XVID and retain LPCM audio uncompressed
By rollo_tomasi in forum DVD RippingReplies: 8Last Post: 14th May 2010, 12:47 -
Western Digital HD TV Media Centre - Missing audio codec support
By Hcw87 in forum Media Center PC / MediaCentersReplies: 5Last Post: 21st Jul 2009, 14:55 -
Dvd Vobs: change audio from LPCM to AC3 2.0
By biancolone in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 07:16
