    Feb 2004
    Bradford
    Hi Peeps,
    Hope you can advise. I am capturing Digital programs of my TV card in Mpeg 2 format. Its excellent quality - but takes up alot of space.
    I just need a simple tool so I can convert mpeg 2 TO XVID, DVIX or .avi is possible.
    Regards
    Riaz
    Riaz Ahmed
  2. Member TaoTeWingChun's Avatar
    Jan 2005
    Mahopac, NY
    Sounds like all you really need is a codec pack. Do a tool search for XVID/DIVX Codecs on this site and install them. Then configure your capture card software and blaze away!
    Post back and let us know how you made out.
    Cheers!
    TTWC
    "I've got a present for ya!" - TTWC
    May 2002
    louisville,ky
    download virtualdubmpeg2 load your video in select a codec like divx and reencode to avi but ive learned with mp2 video that you need to resync audio sometimes.i do captures that way most of the time
    or use autogk!
    Aug 2004
    or avi.NET with bitrate set to 1500 kbs.
    1/3 of the original mpeg, with good quality.
  6. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    I second Autogk
    La Linea by Osvaldo Cavandoli
