hey all,
Have a question for y'all. I have a tv tuner/capture card installed, that is also my graphics card. It can capture mpeg1 and 2 but I don't think avi.
Is there anyway to use a program like virtualdub to capture vhs and encode the vhs to avi by using a mpeg1/2 capture card?
thanks,
schunn99
intermediate encoder
Hi,
What is the name of your capture card? If its a hardware mpeg encoder card like haupauge wintv pvr250 than you can ONLY capture in mpeg.
If it is mpeg only you can capture in mpeg than use virtualdubmpeg2 to convert it to any avi codec you wish.
the capture card is nvidia personal cinema 5700 fx. it's a 128mb graphics card with built in mpeg encoder and tv tuner card.
also basic question with my vhs player that I plan to hook up to the computer, it has a coax cable that used to run into the cable outlet do I need to screw that into the wall before attaching the video and audio cables that connect to the back of the vhs player and the back of my card?
thanks,
schunn99
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 20:42 -
Capture analogue (eg. VHS, analogue camcorder) - AVI or MPEG?
By ManUtdFans in forum Capturing and VCRReplies: 3Last Post: 18th Jan 2009, 19:29 -
Capture Software for VHS to MPEG/AVI
By quantass in forum Capturing and VCRReplies: 1Last Post: 7th Sep 2007, 15:22
