hi to everyone. i am using Adaptec VideOh! DVD Media Center USB 2.0 Edition to capture vhs video tape to my hard drive and have come up against 'Macromedia detected capture device disabled' message and was wondering if anyone can tell me of a device/program that will get around this. i am in the uk.
many thanks
Results 1 to 10 of 10
ADS InstantDvd 2 and ADS DvdExpress both bypass MV
No hacks or mods required. -
forget to ask, are the older ads models of these 2 applications also capable of disabling macrovision?
As far as I know the entire product line from ADS for vid capture bypass MV.
Instant Dvd orig ver (NOT recommended as only hw encodes vid)
Instant Dvd 2
Instant Dvd + Dv
DvdExpress
Not absolutly sure of other products, very little user posts on the forum and the ADS web site no longer gives as much detailed spec information as it did in the past
http://www.adstech.com -
thanks again snaf, i checked out ebay to see if either were up for auction and discovered i could purchase dvd express brand new for £55
Greetings. What type of file is the video captured from the DVD express stored in the the pc?
got the DVD Express at weekend snaf and mv was no problem whatsover, thanks again. unfortunately i am useless with ulead DVD moviefactoy 3.0 which came bundled with the ads device. i use TMPGEnc DVD Author, but unfortunately the audio is well out of sync in finished DVD after using DVD Express to capture video from VHS player. did not present same problem when using the adaptec device to capture? any suggestions? is sonic mydvd compatible with DVD Express and if so i take it that mv is disabled as it is the ads device that overides the mv?
carcf, the files saved to your pc are mpeg when using DVD Express. i used dazzle a while back on a friends laptop to transfer wedding footage from a camcorder and quality was pretty good. dazzle is cheaper to buy too, not sure about macro vision being disabled when using it though.
Converting VHS tapes to DVD, in particular the macrovision issue
By Taildraggin in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 07:40 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 11:57 -
Macrovision like NONE OTHER
By blacksheepdownunder in forum Capturing and VCRReplies: 17Last Post: 22nd Jul 2010, 05:16 -
Is it Old or is it Macrovision?
By Tiggerpaws in forum RestorationReplies: 4Last Post: 7th Aug 2009, 17:31
