Hi guys!
I have a major problem and I need some help...
I compress DVDs using the following method:
I do a 3- or 4-pass of the main movie with CCE, then compress the whole DVD with Nero Recode and finally I replace the Main Movie with VobBlanker (a very easy-to-use and reliable method).
Yesterday I rented Blade: Trinity. I encountered the following problem:
The DVD includes two versions of the movie - a Theatrical and an Unrated one. The Theatrical is shorter and has a lot of scenes in common with the Unrated. The DVD is interleaved and VobBlanker can't handle it correctly.
I tried to replace either the Theatrical or the Unrated and blank the other, but neither works.
I also tried split it to 2 DVDs with DVDFab but it does not do it correctly.
Recode and DVD Shrink to compress it correctly, but at low quality because the movie is large...
Does anyone have any idea how to fix the IFO files so that if I replace the Unrated version and blank the Theatrical for it to work and not to through me out in the middle of the movie???
Other solutions are welcome as well...![]()
Thanks...
You are in breach of the forum rules and are being issued with a formal warning.
Copying of rented DVD's is not permitted.
/ Moderator bugster
Closed Thread
Take a look at DvdReMake. You can definetely split any kind of disk (multiangle, multi title, etc) with it. You can also just get rid of one of the versions (theatrical or unrated) by splitting interleaved blocks and hiding those you don't need (you will need Pro version of the program for this).
thank you dimad!
I 'm downloading DvdReMake Pro at this moment...
I'll give it a shot...
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Replace audio
By quxote in forum Newbie / General discussionsReplies: 9Last Post: 9th May 2008, 01:04 -
Need help with pgcedit's Replace VTST Titles feature TTN's don't match
By ashoun in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 10:34 -
Help deciding what to replace my old TV with
By LT9000 in forum DVB / IPTVReplies: 8Last Post: 1st Sep 2007, 01:21 -
Non-interleaved?
By KingBongo in forum ffmpegX general discussionReplies: 0Last Post: 11th Jun 2007, 06:47
