Hi,
Here there is an info https://www.videohelp.com/vcd#tech
I convert avi to mpg with TMPGenc and use same audio and video prefences with quote above,PAL Video:
1150 kbit/sec MPEG-1
352 x 288 pixels
25 frames/second
Audio: 44100 Hz 224 kbit/sec MPEG-1 Layer2
When i try to burn mpg with nero as VCD, it says "file is not compatible, it will encode again before burning".
Why is still not compatible? What am i doing wrong?
Thanks!
[/quote]
What is selected under the System tab for Stream type?
AFAIK this should be MPEG-1 VideoCD.Cole -
Cole, there are mpeg-1 and mpeg-2 only in Stream Type, not video-cd.
Baldrick, I tried TMPGenc with project wizard and choosed "Pal VideoCD" template then problem solved.Thanks!
But all prefences are same with pal-vcd template, i didnt understand why its doing different, can it be done without project wizard?
What's the most "Device Compatible" container? is it, .mp4 or .mkv?
By thezanny in forum Video ConversionReplies: 11Last Post: 3rd Jan 2012, 09:07 -
So what do I do with "NTSC Compatible" .mpg file?
By brassplyer in forum Authoring (DVD)Replies: 6Last Post: 29th Sep 2009, 16:12 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 17:25 -
Compatible Burner for Womble's "MPEG Video Wizard DVD"?
By cyberboy in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 23:25
