When I click on add assets, I pick what I want to add and I have no clue where to find them again as the 'sheet' that it usually goes to disappeared. Any idea how I can get it back? I tried to re-install, repair, etc... nothing has worked? Maybe a option for future releases to lock the movements of the feautures?
Anywho, if you can help me that would be cool
If you select a file as an asset , it should show down at the bottom of the gui in the Asset section. Are you sure you hit the Open button after selecting the asset file?
Which version are you using? -
Awesome, it worked! Thanks so much man.
Any idea why it dissapeared?
And maybe in future releases can there be a option like something similar to "Lock The TaskBar" so the tool bars, assets, VTS's can not be moved? -
Not sure why it happened, didn't do that in earlier builds. Perhaps ChrissyBoy has the answer.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
