My goal: couple of avi's in one dvd.
The guide i used: https://www.videohelp.com/guides.php?link=765
programs i usedIKO,DVD-lab.
ive done al of the steps in the guide from doing the conversion in diko to making the dvd with DVD-Lab.
the problem is that after i make the dvd with dvd-lab and play it in dvd i have audio delay that get worst all the time.
ive tried multiplexin the audio,video files in other programs like imagompeg-muxer and it done nothing.
if u can help pls do it.
thx
I would try another authoring tool and see if it works better. If it wont work try another converter like divxtodvd, thefilmmachine or don't use an all-in-one-crap tool.
Sometimes I have AV sync probs when joining AVI files and converting them to DVD. I join them with Avisynth and use audio delay offsets to correct the sync and then either encode it with CCE or if it's a rush job and I don't feel like exerting myself I'll just open the avs file in VirtualDubMod and resave it as an Xvid file then feed that fixed file to one of the wham bam thanky ma'am! apps like divxtodvd and let it do all the work and spit me out a DVD.
flonk!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Audio delay reported in MKV and what to do with it when adding new audio
By pascal in forum AudioReplies: 14Last Post: 30th Dec 2011, 12:07 -
.ts to .mkv audio delay problem
By AlienWare in forum Video ConversionReplies: 6Last Post: 5th Feb 2011, 15:42 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
DVD / VOB audio delay problem
By TrashCompaqtor in forum AudioReplies: 9Last Post: 22nd Jan 2009, 05:56
IKO,
