Hi, I would like to know what the best process is for taking a commercial DVD you own - extracting specific scenes you want - and then re-burning them on a newly authored disc - all while keeping the same high-quality of the original transfer.
I'm somewhat familiar with the more popular DVD and video conversion/authoring programs but if somebody can sort of lay out their own definitive version of how they do this - that would be great.
Right now all I can think of is this:
1. Extract DVD vob files from original disc with DVD Decrypter.
2. Make a Divx file out of the necessary vobs by using DVDx or some other programs.
3. Edit the scenes you want in TMPGEnc and covert them to DVD Mpeg files.
4. Import those files, reauthor and burn new DVD with a program like Sonic MyDVD or something.
However, I would NOT even know what settings of the above programs I should use to be able to retain high picture quality, etc.
Somebody help me out here...
^^^OK, I'll see if I can learn about that and I'll start trying it...
But is it true that I definitely should do the three other steps as stated? -
You could even open the vob in virtual dub mod and edit it there then frameserve from there to tmpgenc.
Donadagohvi (Cherokee for "Until we meet again") -
1. dvd decrpyter to rip vob
2. edit in virtual dub mod and frameserve to tmpgenc
3. encode your "filename.vdr" in tmpgenc
4. author using the software of your choiceDonadagohvi (Cherokee for "Until we meet again") -
Hmmm, Ok, well, I'll have to learn about "frameserving" - haven't done that before. I do use ViirtualDubMod though (and obviously TMPGEnec). Guess I'll figure it out. Thanks.
Frameserving is just sending the edited file directly to the encoder without having to save an intermediate avi file.
Check here
https://www.videohelp.com/guides.php?guideid=99#99Donadagohvi (Cherokee for "Until we meet again") -
Once you have the vobs ripped to your HD you can then load and edit them in TDA, (ADD DVD FILE) you dont need the divx conversion.
If the vob files are from the same DVD then DVDShrink will do this in RE-AUTHOR mode.
Both quick simple and 100% quality.
Start with DVDShrink and work from there. Check out MrBass's guide to DVDShrink (Re-Author mode) if your new to this:
http://www.mrbass.org/dvdshrink/No2: We want Information.
No6: You wont get it!
editing with alternate scenes and audio
By }{eywood in forum Authoring (DVD)Replies: 18Last Post: 17th Feb 2011, 03:23 -
high quality .mkv from DVD?
By avextraxjp in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2010, 00:28 -
High-def video editing & DVD conversion
By alpheus86 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 5th Mar 2010, 11:41 -
DVD to AVI (high quality)
By bob_smitty in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2009, 10:39 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 08:30
