I need to find DVD-RW that will work on a Dell installed Phillips 8631 RW Drive and a Toshiba DR-2 DVD Recorder. I have yet to find a disk that will work for both even though they both burn to DVD-RW. I'd like to use them to convert VHS to the recorder then load them into my PC.
Are you "finalizing" the RW disc before attempting playback??? if not, that's your problem.
I use RW media as an intermediate storage medium to convert tape and TV recordings to XVID files that I store on my PC. I have found that everything works more smoothly when I do a complete erase after I finish with a disc. This does a much better job of cleaning up the disc. I have far fewer problems when I do this. A Kprobe scan after a disc is rerecorded after a complete erase compared with recording after a quick erase shows why. The scan results after a recording made over a quick erase are far worse. Since the reflectivity of RW media is less, anything you can do to improve the recording helps. Interchangeability has always been an issue with RW media.
PowerDirector 8 doesn't work with USB capture devices
By chris18 in forum Capturing and VCRReplies: 0Last Post: 10th Feb 2010, 07:28 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04 -
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 17:50 -
DVD Decrypter Not Reading Devices
By JoRodd in forum DVD RippingReplies: 4Last Post: 14th Apr 2009, 14:33 -
USB Devices don't work!!
By peomp in forum ComputerReplies: 6Last Post: 5th Jun 2007, 14:12
