Closed Thread
    Nov 2004
    Looking to find out information on burning PS2 games and what software is required. and how to guide on completing this task.
    USA
    This is a video site. You would have more luck trying a Google search for 'Burning PS2 games'. You will find quite a few links with that, full guides and all.
    Nov 2004
    Thanks alot will try that
    Jan 2002
    This has been asked a gazillion times. A simple forum search would have uncovered a mountain of posts and info.
    Anyway, you need a modchip to play any backups on a PS2. Once your system is modded you can simply copy the PS2 games the same way you would copy any other disc- there is no copy protection.
    I would get a professional to do the mod- there is a lot of soldering involved. There are a few non solder options but they are half assed solutions
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    This is not www.gamecopyworld.com
    If in doubt, Google it.
  6. Just use any dvd copy software.
    Its that easy. They are not copy protected until you put in a ps2.
    Use -r media, write at 2x. & get some sort of mod.
