I got a bunch of MPEGs I want to burn on a DVD with a menu. The menu uses the artwork of the MPEGs as the icons on the menu.. Problem is the artwork is just black squares. Could somebody reccomend a tag editor or something to change the artwork so I don't have a really ugly menu? thanks
If it is OK with you to have a still menu, then it can be done quite easily with DvdReMake Pro:
1. Import disk into DvdReMake Pro;
2. Save menu background as a bitmap (right-click in preview and select "Export frame"). It is a motion menu - choose the frame you like most as at the end of this procedure you will have still menu;
3. Open saved bitmap in any editor and edit it the way you like;
4. Download muxman (http://www.mpucoder.com) and author a dummy DVD with edited bitmap
5. Import this dummy DVD into DvdReMake Pro;
6. Open your original menu in preview, right click and "replace with still" (DvdReMake Pro 3.1+ is required).
7. Select block with your edited bitmap
That is it. Now you have menu with new background.
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Changing the shape/size of an mpeg
By cawright1 in forum Newbie / General discussionsReplies: 13Last Post: 9th Oct 2007, 13:28 -
Changing AC-3 Bitrate
By kotton in forum AudioReplies: 5Last Post: 1st Sep 2007, 22:29 -
By kotton in forum Video ConversionReplies: 2Last Post: 1st Sep 2007, 21:05 -
Changing my IP address?
By Akabane Kurodo in forum ComputerReplies: 24Last Post: 7th Jul 2007, 08:28
