Hi All,
I downloaded the DVD files of a bootleg concert video from sharingthegroove and used Nero express 5.5 to burn to a DVD-R but the disc won't play on my Panasonic DVD-RV31 but will play on my PC's Pioneer DVR-105. There are no menus displayed, just the concert video. The files downloaded followed the structure listed at https://www.videohelp.com/dvd#struct. The Panasonic usually plays anything I feed it. I checked the files on the DVDR and they too follow the file structure. The message displayed by the Panasonic on the TV is "This type of disc cannot be played please insert a different type of disc". Again, I've played many DVDRs w/this player(I don't recall if I'd used Nero to burn, most were ripped & burned w/DVDDecrypter). Are there settings in Nero I can change or perhaps another tool to burn the DVD? Thanks!
Dan
try reauthor it with tmpgenc dvd author, add dvd video.
use DVD Shrink works everytime for me on d/l video_ts folders.nero is hit and miss,IMO.
It could also be the wrong region code, IE region 2 and you are using a region 1 player or type in USA NTSC and your video could be PAL.
My Sony DVD Player is region 1 and NTSC because I'm in the USA.
Good Luck
P.S. as Baldrick says try to reauthor in TMPGEnc DVD Author, That will tell you if your video is NTSC or PAL and author as proper region to play.
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 13:01 -
Issue getting burned dvd-r to play in Sylvania portable dvd player SDVD8727
By deviant_delusion in forum Authoring (DVD)Replies: 2Last Post: 18th Aug 2010, 18:02 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Dual Layer DVD successfully burned, but won't play on a DVD player Help Plz
By Ruudboy in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2008, 02:09 -
Suddenly Nero SHowtime won't play DVDs that I've burned.
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2008, 00:13
