I've got asn EnvisionEN-910e monitor on a Dell 6420NX box which came with S# Pro Savage on board for video.
It is barely acceptable. I want to spend a few bucks upgrading my video and keeping the monitor.
The question is - which Video board do I get? I want the biggest bang for the buck. Not necessarily anything expensive.
I don't play games. Mostly it's videos. MPG, Avi, DVD, VCD and the like. I may play a FEW games. Some that I got for the kids like Barbie and some others won't even install. And the ones that do are having a lot of trouble.
My needs are simple. I want to smooth things out and want to spend a reasonable amount on a low to mid range card to upgrade what I see.
Thanks for your time.
thats pretty much the way i think. i don't play alot of games either, but now its nice to know that i can, if i want to.
i have an NVIDEA card, but my reccommendation is to stay away from them. they do have a lifetime warranty, and now i know why
check my stats to see my current card. i have only had it a couple of days, and have not tested it fully, but so far it runs VERY well. it was $150 CAN. you can probablly get it cheaper where you live tho
If you aren't heavy into games, the ATI 9200-9250 cards are enough.
http://www.newegg.com/Product/ProductList.asp?Submit=Go&DEPA=0&type=&description=ATI+9...&Go.x=0&Go.y=0Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Upgrade video card for old Dell GX280
By neworldman in forum ComputerReplies: 1Last Post: 9th Mar 2011, 01:31 -
Upgrade to What Video Card?
By jollyjohn in forum ComputerReplies: 5Last Post: 8th Jul 2009, 11:48 -
upgrade video card reasonable?
By gooberguy in forum ComputerReplies: 2Last Post: 23rd Apr 2009, 12:00 -
Upgrade video card to ATI HD4670
By hulinning in forum Media Center PC / MediaCentersReplies: 2Last Post: 9th Jan 2009, 20:55 -
Time for a Video Card Upgrade?
By dj4monie in forum Media Center PC / MediaCentersReplies: 21Last Post: 19th Dec 2007, 04:35
