  1. I am having trouble finding a program which will allow me to take multiple video sources and put them into the program to then make up one overall video from these sources in a mosaic like effect. The best example to explain this would be in Tupacs video changes. I have a program which works for stills but I have yet to find one which does videos. Does anyone know any program like this? I would try doing it manually in after effects or avid but it is a very tall order and I don't know if it is even possible to do manually.
    Thanks in advance.
    Apr 2004
    Miskatonic U
    Actually, there is a tutorial over at the creative cow website to do just that in after effects. It's the video wall tutorial.
    Shine Video Wall -> http://www.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=/articles/hansen_ja...ine/index.html
    A different approach -> http://www.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=/articles/fischer_j...all/index.html
    Read my blog here.
  3. Hmm thanks for the links that will be a new way of doing things but that isn't quite what I wanted. I need to get that video wall to display a video made up from all the small videos. Watch the 2pac video towards the end to understand what I mean as I don't know if what I'm saying is 100% clear.
    May 2001
    CHEERS GARRY
  5. use dvd architect....just put all the clips in how you want to....and render as a motion menu
  6. Originally Posted by stunner21
    OHHHHH ok i just saw the video....its just a video wall and a picture behind....as it zooms out the transparency of the video wall is decreased....so make the video wall....lower the transparency and stick a picture behind it....and if you look closely on each of the videos after it zooms out, there are only a few different videos and they are are all just repeated over and over again, spred out
