hi all
i have been told to use mybatchconverter for converting my mpeg movie file to avi my prob is that when i load the file to be converted i get asked for a destination file/folder when i select one and click ok it does nothing
can someone plz plz plz help me out with a description of what EXACTLY i have to in plzzzzzzzzzzz
my heads done in
many tnx
I couldn't get that program to work either. It's supposed to list all the files for conversion in the main box, but I never saw anything. Maybe a problem with direct X. Their link is dead for that. They also want you to download a codec pack, which is generally a bad idea. That's listed under requirements, but no way will I put one of those on my computer. It would most likely interfere with the codecs I have.
That looks like a program to avoid.
Try Virtualdub Mod with the XVID codec (both free). It will combine multiple files by using 'append'. Also has other AVI choices.
If you have a DVD length MPEG to convert, try FairUse Wizard or AutoGK. I use them for DVD to XVID conversion.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
