when using svcd2dvd 2 latest version i converted a 3 mpg file vcd into a dvd but it has 2 titles making dvd player think it is 2 films?
If you use "quick DVD" then the logic for auto laying out the DVD is based on filenames. If your filenames are not standard (like movieA.mpg, movieB.mpg) then the logic may not get it right in this case you just simply need to create the DVD structure yourself. In this case a single TitleSet with 3 Titles.
It does that anyway.
but i cant drag a bin file into a title set before converting it can i??
Ok sorry. You put the bins in the asset window. Then from the toolbar do "Assets->Extract mpegs from bins" Then when that is finished you have mpegs in the asset window - then you can do the manual layout.
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
The Independent Film Channel - efficient film challenge - cash prizes
By minidv2dvd in forum Latest Video NewsReplies: 1Last Post: 23rd Oct 2009, 10:44 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
No Titles
By jinboleone in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2007, 19:55 -
My DVD Film backups are 'freezing up' near end of Film
By Artom in forum Newbie / General discussionsReplies: 5Last Post: 18th Jun 2007, 04:01
