Hi, i have a movie that the subtitles are forced (i think thatīs the term...), do you know how can i get them off?. If it helps... thereīs no other file besides the ".avi"
Thanks !!
Never tried it but AVISubDetector looks like it might work.
Not sure, but if they are burned into the video, there may not be much you can do. -
Only real way to remove hard subs is to crop them off or cover them with say a solid colour.
How to Remove subtitle track from .MKV ?
By Clifurd in forum SubtitleReplies: 2Last Post: 13th May 2011, 23:32 -
Best way to remove subtitle stream?
By rmdeboer82 in forum DVD RippingReplies: 1Last Post: 7th Jul 2010, 05:15 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
forced subtitle problem in avi.net with dvd rip of main movie only
By nathanm in forum SubtitleReplies: 0Last Post: 30th Apr 2010, 09:37 -
Remove subtitle stream from MKV
By NinjaPanda500 in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 14:59
