I am new to Video capping.
I first 'published' video looks okay, but I want some recommendation. It is of he Offspring's new video "Defy You." You can dowloaded it at http://www.videopimp.com/videos/1217HARDOFFSPRINGDY.zip . You need to unzip it.
I use Huffyuv to capture, uncompressed at 640x480.
I then encoded it to vcd with TMPGEnc at best quality. I Clipped the frame, removing not just the letter boxing on top and bottom, but also on the sides, which expained the video
The sound is from a MP3 put in using Ulead VideoStudio.
What can I do to make my videos better.
It looks quite good, seen on a computermonitor on which the image is worse than on a real television screen so I guess there ain't much more you can do to touch up your clips. Maybe you should experiment with the filters TMPGenc has to offer... if you know what you do (I don't use filters so I'm an no-know on this) you can get better quality I guess.
Ofcourse a better (semi-)pro captureboard will help alot also but this cost money instead of time
Test Caps - various composite and s-video cables
By BrainStorm69 in forum Capturing and VCRReplies: 36Last Post: 12th Apr 2012, 13:51 -
Vid Caps
By moonshadow in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Feb 2012, 09:31 -
A way to auto-make screen caps from videos?
By Scav2003 in forum MacReplies: 15Last Post: 20th Aug 2010, 00:05 -
My Caps Come out very Blurred
By zxfactor in forum Capturing and VCRReplies: 9Last Post: 17th Feb 2009, 06:10 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 11:48
