  1. Is there any way I can import Quicktime movies into Adobe Premiere Pro?
    Apr 2002
    Oskeeweewee Ontario
    How would it be any different than importing .AVI files??
    I'm assuming as long as you have the correct codecs, then the Quicktime files should edit flawlessly...
    Good luck!!!
  3. I've managed to import Quicktime files into Premiere Pro ... I had to reinstall Quicktime to do this. Dunno why I couldn't import .MOVs before.
    But now I have another question ... why is there no Quicktime editing mode in Premiere Pro?
    Apr 2002
    Oskeeweewee Ontario
    Are you reffering to the presets that are offered upon loadup??
    If i'm assuming the case, then you'll simply have to go to the tab of the same page, and create a Custom preset..
    It's a bit tedious, but at least you can create one that will match your source footage...
    Good luck!!
    Aw crapp!!!
    666 posts...
    That can't be good.. :P :P
