hi,
i have a video that has 2 different audios for it.
i have the one audio working fine, the file is a .mpa file
the other is a .mp2 file
the .mp2 file doesn't work or if it does i can't access it through my dvd player.
any help would be much appriated.
mpa and mp2 should be the same thing - mpeg1-layer2 audio. If you can play one, you should be able to play the other.
First test - have you put both audio tracks into their own audio slot on the movie asset ?
Second test - can you hear both tracks when playing back on the PC BEFORE burning to DVD ?
Third test - assuming you can hear both on the TV, can you switch audio tracks on your player using the audio button ? If so, can you hear anything ?Read my blog here.
VOB2MPG PRO: Multiple Audios & Subs?
By kwanbis in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Jul 2011, 19:59 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 1st Jan 2010, 00:01 -
DVD Lab Pro
By matthewjohn23 in forum Authoring (DVD)Replies: 5Last Post: 20th Mar 2009, 13:35 -
Karaoke DVD -> Chapters (2 audios) -> .mpeg (2 audios) ???
By webking1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2009, 12:49
