Having got myself a DVD Recorder now, I have used this for a couple of off air captures that I wanted to keep.
As the capture was a 16:9 resolution, using TMPGEnc DVD Author, I converted the DVD to a MPEG file.
Next stage I used DVD Patcher to convert the MPEG to 16:9.
I then used TMPGEnc Plus to convert the video to M2V and used DVD2AVI to demux the audio to WAV (as I am using TMPGEnc DVD Author, I know that it won't accept the AC3 audio track from the ripped MPEG).
So far so good.
Now to re-author: TMPGEnc DVD Author accepts either the MPEG or the M2V file and accepts the WAV. However, in this particular instance, the TMPGEnc DVD Author is telling me that the combined files are too big for the DVD using either the M2V or the MPEG!
The MPEG came off a DVD, it should be rights go back on again!![]()
What is it that I have missed?
Cole
Check and see what the output size limit is on dvdauthor, it may be smaller than the max capacity of a blank disk. You can run dvdauthor and tell it too ignore to oversize error and use a separate burner to burn the file(s) and you may find it will burn with no problem. Lastly you can always run the result through dvdshrink to get a file of the correct size. Nyah Levi
Thanks Nyah.
The total for the film was very very close to the DVD capacity, so I didn't want to chance it. However, in a further search I can accross this thread:
https://www.videohelp.com/forum/viewtopic.php?t=274497&highlight=ac3+tmpgenc
I tried to author a DVD just by using the original MPEG file and not worry about the wav etc. The outputted VOBs have a soundtrack. Now reading the threads on this site, I was led to believe that without the AC3 plug in I would get a silent video.
I now see that the AC3 issue is only to hear the audio in the editing stage.
Cole
how to demux MPEG 2 For DVDauthergui ?
By ashe09 in forum Video ConversionReplies: 6Last Post: 5th Nov 2011, 20:28 -
Big demux issue
By Felo in forum Video ConversionReplies: 4Last Post: 6th May 2009, 20:03 -
Is there a way to normalize audio of VOB and MPEG without demux?
By edong in forum AudioReplies: 7Last Post: 4th Dec 2008, 22:40 -
Reauthor a DVD with new audio
By nuguy47 in forum Newbie / General discussionsReplies: 2Last Post: 27th Jul 2008, 12:19 -
easiest way to demux audio from DVD then add it back in?
By fotty in forum Authoring (DVD)Replies: 4Last Post: 12th Jun 2008, 08:46
